does anyone make a glow in the dark flue temperature gauge? Our living room is fairly dark in the evening and I have to get up and walk across to check the gauge. I’m sure the exercise isn’t hurting me but it’s annoying.
Unlike any other stove with a bypass I’ve had, my Woodstock will roar with the bypass open. I mean it will really go crazy in just a few minutes! The bypass is really small, 90 off the back, 2 45’s at the ceiling. It’s surprising to me, I’ve got to really watch it close.Yup, same worries as any other stove until the bypass is closed.
I have one of those that kicks on the high speed fan at a set point. An alarm can also be attached.Are you against going digital?
Auber makes small digital readouts that are visible from a long distance.
I have a couple around for no other reason than I can see them at all times of the day.
You don't want that...don't open the air as far.Unlike any other stove with a bypass I’ve had, my Woodstock will roar with the bypass open.
I generally don't have it much over 2 once any wood is catching well, and cut it to under 2 before long. As you've seen, under 2, small adjustments make a big difference.
Nope! I want it up to temp as fast as possible. If it can’t handle it I’ll replace it with something that can!You don't want that...don't open the air as far.![]()
Any stove will handle a roaring fire...for a while. I don't drive to the grocery with my foot to the floorboard, either.Nope! I want it up to temp as fast as possible. If it can’t handle it I’ll replace it with something that can!![]()
I respect a machine, even if it is a simple one.
Ya, I’m just funnin.Any stove will handle a roaring fire...for a while. I don't drive to the grocery with my foot to the floorboard, either.I respect a machine, even if it is a simple one.
I assume you are half-kidding since you said you "keep an eye on it." I know you have your bypass retainer thingies to worry about...![]()
