A few nights ago, I loaded up my insert and let it run with full air for a little while to get it up to temperature.  The temperature was at approx. 480 F and then I realize that the stainless steel flue is glowing red from just above the adaptor to the block-off plate.  The flames were pouring over the baffle and I guess were being sucked up the flue.  I turned the air all the way down, and after a little while, the pipe stopped glowing, but it was a scarey situation.  After the air was turned down, the temperature only increased to 530 F.  I confirmed this with a second magnetic temperature gauge.
I have a 6-inch M-Flex stainless steel liner (0.006) from the top of the insert to the top of the chimney (18'). The insert is in a corner masonary fireplace. So the stainless steel flue goes through a slight incline for about 5 feet through 11" X 11" terra cotta, and then when it gets to the exterior chimney it goes straight up through 11" X 11" terra cotta lined chimney. My stainless steel liner is uninsulated, but I have a top stainless steel plate with 5-inches of ceramic fiber insulation under it, and I have a block-off plate above the insert with 5-inches of ceramic fiber insulation on top of the block-off plate.
Now the flue has a brass color between the insert and the block-off plate. The heat output of this insert has been disappointing as the insert has never gotten above 530 F even though I have tried various air settings and different wood from friends. Even when the flue was glowing the heat coming off the insert was minimal.
My insert always gets a good fire going, and when I turn the air down, I get a good secondary burn, but the heat output is poor. What is the problem? Is it possible that I have too much draft?
		![[Hearth.com] Glowing Flue Pipe](/talk/data/attachments/7/7279-7e3c251e7dcb5c6ad6254f7a2555b616.jpg?hash=fr6TV5gyFA)
