Going to look at a used T6, what should I consider?
littlecanoe
7
Bluegrass State
First time post here. I've reviewed the stove discussions on the Alderlea T6 and the Jotul F600.
I've been planning to buy for a few years but had not narrowed down the choice until lately.
The choice is swayed a bit from the offer that a friend made.
He had purchased a T6 about 3 years ago and burned it for 1.5 winters before converting to an indoor wood furnace arrangement.
He stated that he knows of nothing wrong with the stove it just didn't meet his expectation/needs for the particular application.
I'm going to run over in the next couple weeks and take a look but wanted to ask those with experience with these stoves
some of the specifics that i need to check to make sure that it's in as new shape.
Please throw out ideas. This will be my first wood stove, I did grow up with wood heat and I was the fire starter stove stoker.
I have familiarity but am a bit more than rusty so I'll be scouring the topics in the forums.
Also, do you think the price a good one? It was offered at 1700$ with the blower feature. Compared to new, this is a good bit below
price based on 2500 Retail (free blower before 9/30/11) when considering taxes and the 10% rebate.
Thanks a bunch for reading my post. Looking forward to the voices of experience!
lc
Can't comment on the T6, other than the people that have one, Love it.
2 questions/comments..
1st is why did your buddy stop using it? This is Large stove that can heat well. If the wood you burn is not properly seasoned (2 months is not seasoned) then the stove will not burn properly and put out little/poor heat. Which leads to my 2nd question?
2. What does your wood supply look like? How long has it seasoned? If you don't have any yet. You could be in for a frustrating 1st year (as your friend may have experienced). I would take a look in the Wood Shed Forum. Oak takes 2-3 years to properly season (3 is best). Its good to get 3 years ahead, so you never have to worry about burning "Wet" Wood. Even Ash and Silver maple are best with a year of seasoning (quicker seasoning wood)
Welcome lc. Look for obvious signs of abuse. Open up the trivet top and check the paint. If it is black, that's good. If it is grey or whitish that would be bad. On the inside of the stove look for cracked brick and make sure the baffle is not sagging. In the front of the firebox at the bottom front edge there is a metal boost manifold that sits loosely in place there. Make sure it is present and not warped. Other than that, there should be no signs of rusting, bent parts, etc.. This is all unlikely if he has run the stove correctly. If you can take pics and post them here, all the better.
Thanks fella's. I'll try to take a look next week and snap a few pics.
From what I understand, he converted to a different system due to the style of house not being as compatible with convection/radiant.
lc
Don't know how I missed this thread but if it truly hasn't been used that much it should be in great shape. I agree with BeGreen that you definitely need to look for signs of overfiring on the top of the stove such as white spots and you should check the baffle to make sure it's not drastically sagging in the center however keep in mind that the baffle is fairly big and it's not uncommon for them to sag in the center a little bit. Make sure you take a camera with you and if you have any concerns take a picture and share it with us......I'm sure we will be able to give you an opinion whether you want it or not lol :-)
Others may know the answer to this, but take a read over the warranty and make sure it is transferable to you.
I'll welcome the opinions fellas.
Thanks for looking and assessing this unit.
I was able to get a face to face with the stove and confirmed that it is a T6.
The only flaw that I saw was a broken fire brick in the back.
I've posted some pictures and will try to add another post with a couple more pics.
Big thanks to all,
lc
  • [Hearth.com] Going to look at a used T6, what should I consider?
I hope that I showed all the critical areas in the pictures.
From the creosote built up on the top of the fire box I believe that the wood burned was not well seasoned.
The stove was not performing to expectations in heating the basement and then getting heat up to the living area.
Externally the unit looks to be in fine shape. Seals on the doors were in good shape. The one fire brick in the back on the right was cracked.
I hope that the pics show what you need to help identify condition.
Please shoot questions my way. I may have seen more than registered and a good question might help me remember more of what is there.
lc
No questions other than did you get it? If not, go for it!
The only very minor thing I see is the baffle retaining pin appears to be missing. The rear corners, looks like mine-- which after I added the blower noticed the rear corners do seem to burn a little cooler, chimney is fine. The rest of the unit looks like it was used properly.
I'ld say the $1700 is fair and personally would pull the trigger -- if I didn't already have one.
Looks to be in good shape I would pull the trigger if I was looking for one.
