I'm considering buying a used Blaze King King (KEJ1107, I think) for $750. Can't go wrong at that price, right? Or no?
From another thread:
I would have to drive 150 miles to see it, and I know that much driving will make it hard to come home without the stove. I'd like to know what problems I could should look for before bringing it home. It's my understanding that I can't really check the cat or the cat thermostat without running the stove. I can see the cat, but I can't really test it without running the stove, is what I understand.
I realize that I'd have to either replace my 6" chimney with 8". I mentioned that to the seller, and he said he's selling it for his father-in-law, who (and this is third-hand, of course) used a reducer with this stove to run it with 6" pipes, and found that he had to replace his 6" chimney (Class A, if I understood correctly) every two or three years. The ad says he installed a propane furnace so didn't need the Blaze King. This all raises red flags to me, but it's not necessarily a deal-killer to me. I can see how both might be true.
Any idea what happens when a 6" flue is used instead of the recommended 8"? Could it be that the exhaust would flow at the same speed or rate (feet per second), but because of the smaller cross-sectional area, the volume of air would be lower? And lower volume, higher flue temperatures, shorter chimney life? I have trouble believing that the difference would be great enough to cause such damage. Any thoughts on this?
Thanks in advance!
The only thing that I would be looking for on a used bk is the presence or lack of heat damage to the bypass retainers. The rim around the bypass opening on the inside roof of the firebox where the bypass door closes. These things (like a picture frame around the opening) can melt down and are extremely difficult to replace requiring cutting and welding.
Thanks in advance!
I would go ahead and bite the bullet, and get 8" chimney...especially if your stack isn't real tall.
My wife told her cousin about it and she, being a former sweep, told her she needed to go to the top with pipe. She failed to mention that we were supposed to use chimney, not connector pipe.
