If you have mold growing I would gut the whole bathroom and start fresh. To me that is the easy way to do a bathroom.
Mary-Anne said:Unless code requires it, I was hoping to leave the toilet in place.
Other than that, we will nearly gut the bathroom.
There would have to be some sort of slope toward the drain. If the floor is sloping the wrong way, you may have to build up the entire floor if you cannot simply drop the floor toward the drain. If you have to raise the floor, the toilet flange will need to be built up. I just got done re-tiling my bathroom floor and shower.Mary-Anne said:I was assuming that we would not use a "shower pan" at all. I assumed that we would just tile the floor with something not slippery, and tile the shower floor the same way. There would be an edge between the shower and the floor, which the wheelchair would compress when it rolls over the edge.
I talked with Goose earlier today, and what he wants has just gotten 2 notches more complex than what I had been thinking about.
First, he does not want to use a shower surround, not because it would not work, but he wants us to indent shelves between the studs behind the shower, in the space of the wall between the shower and the next room.
Second, he wants us to redo the entire bathroom floor, which was new just a few years ago, because water will certainly leak from the roll-in shower, and we need to tilt the floor so all the water runs into the shower drain. How this gets past the edge of the shower is unclear to me, but that is what he wants.
LLigetfa said:There would have to be some sort of slope toward the drain. If the floor is sloping the wrong way, you may have to build up the entire floor if you cannot simply drop the floor toward the drain. If you have to raise the floor, the toilet flange will need to be built up. I just got done re-tiling my bathroom floor and shower.Mary-Anne said:I was assuming that we would not use a "shower pan" at all. I assumed that we would just tile the floor with something not slippery, and tile the shower floor the same way. There would be an edge between the shower and the floor, which the wheelchair would compress when it rolls over the edge.
The tiled shower walls need to have a waterproof membrane, especially around the cubby holes inset between the studs. I used Schluter KERDI. Each cubby will need preformed corners, both inside and outside corners. When installing the concrete backer board, make allowances for the additional layers of KERDI that overlap. I suggest you use 1/2" backer on most of the wall and 1/4" in and around the cubby which will give you 1/4" of wiggle room. You also need to leave room for corner molding to edge out the tile. You can also use KERDI for the shower pan. http://www.schluter.com/4625.aspx has all the materials and instructions.
LLigetfa said:Instead of adding wood blocking everywhere, you might consider lining the entire shower wall with 3/4" OSB and then 1/4" HardieBacker put on with modified thinset and their special screws. The OSB would be more dimensionally stable, add lots of strength to the wall should one lose their balance and fall against it, and allow you to drive screws anywhere.
http://www.jameshardie.com/homeowner/products_backerboard_quarterInch.shtml
Flatbedford said:LLigetfa said:Instead of adding wood blocking everywhere, you might consider lining the entire shower wall with 3/4" OSB and then 1/4" HardieBacker put on with modified thinset and their special screws. The OSB would be more dimensionally stable, add lots of strength to the wall should one lose their balance and fall against it, and allow you to drive screws anywhere.
That's what I was thinking too, except I was thinking 3/4 plywood. Probably only because I haven't used USB before. Does OSB hold screws as well as plywood? It would be nice to know that you have pretty much unlimited fastening on the wall.
Hunderliggur said:Looking at your floor plan, I would recommend taking out the wall that create the hall between the bath and the kitchen. It is probably not load bearing but Tim could check. If it is load bearing, it would be fairly straightforward to put a header (Double 2x12 or 2x10 depending on opening width) to handle the load. That would make it much easier for a wheelchair to get into the bathroom and bedrooms. You may also want to consider getting rid of the door on the bathroom closet or perhaps putting a lower cabinet with upper open shelves. I don't think Goose needs any extra doors.
