Hi, we had our furnace go out, and it's being replaced in 3 weeks. We have an older Lopi stove insert (simple, no blower, etc.) in a masonry fireplace with no exhaust pipe - the stove just vents into the bottom of the chimney. We've got to use this as our main heat source for the next 3 weeks, which is not something we've done for any length of time before.
Have found a supplier for split, seasoned alder for a decent price. Is a half cord enough for the 3 weeks? We'd like to have a little but not a lot left over at the end.
More details:
Thanks!
More details:
- We live in Puget Sound area of WA state, just N. of seattle
- Right now highs are upper 40s and lows are right around freezing. Winters are usually mild, not that many hard freezes
- House is about 1900 SF
- Furnace fan still works, and the return is right above the fireplace (good design!). So we have a built in way to distribute some of the heat
- House is well insulated. We haven't been running the stove at night, and temp only drops 5-6 degrees between midnight and 6am.
- Other than that, we'd run it all day most days, as I work from home.
Thanks!
I'm not sure but I think that to be legit, the bare minimum, the direct connection shown below, would have to be done with insulated rigid chimney or insulated flex liner. As bholler has stated, almost no masonry chimneys have the required clearance to combustibles where an un-insulated chimney could be used.![[Hearth.com] Half cord for 3 weeks? [Hearth.com] Half cord for 3 weeks?](https://www.hearth.com/talk/data/attachments/252/252061-7a0c5b6bdc4e83da1a7582b02e030851.jpg?hash=pv_ysBL6Px)
