Handle Nut Replacement
avsmusic1
Burning Hunk
218
CT
I apologize in advance as this may be the dumbest questions asked here today but I want to be safe.
I have a regency 2400 insert and lost the door assembly nut that holds the latch on the interior of the stove. Regency parts only sells the full assembly for $60 but I only need the nut. Obviously I can get a nut at any number of places, but I'm wondering if I need something special given it's going to be inside the firebox.
Any guidance would be appreciated
Take the assembly with you match the nut thread.
Note that the nut will probably be metric thread.
So I don't need anything special - anything at the hardware store that fits is fair game?
So your setting up a new stove install if this was mine used or new Black steel nut with washer nothing special dealer if new should of give nut to you
Reactions: WiscWoody
I wouldn’t think so, if you have some anti-seize you can put some on the threads. The oils in the anti-seize will burn up but the copper or aluminum in it might survive to make the it easier to disassemble later on down the road.
swung through the local hardware shop and snagged one - thanks all
I was hoping it would it would be that simple ;lol
What is the size, thread?
