P
Pallet Pete
Guest
I am posting this because I see a lot of file questions so here is my grinder review.
Purchased 8/2010
I have been using a Hand file for a long time then one day I see a Harbor Freight add advertising a bench top chain grinder and I think for about two seconds then buy the sucker. The directions suck big time and I end up watching the demo video that shows you how to use it on HF's website and get a good grasp of it. It was a battle for the stop to work properly and hold the chain in place it made me go insane for a bit to be honest with you then I got an idea :coolgrin: !! I modified the guide/stop so it was more stable by simply adding a couple washers to it and wamo it works.
I sharpened the first chain and had some issues with the grinding arm being sloppy when I tried to sharpen the tooth it also got a washer on one side and it has no more slop. After the washers it is nice and tight I can just barley touch a tooth and it is razor sharp my test was simple I cut a sheet of paper by pulling it over the tooth and it sliced like butter. Ever since then it has performed flawlessly just be patient and this sharpener works like a dream! I do still use a hand file in the field every tank of gas I give the chain one pass per tooth and it stays crazy sharp because of that.
Here is the link to the sharpener it is 49.99 regular however I got it for 29.99 on sale if you wait for a sale you can too.
http://www.harborfreight.com/electric-chain-saw-sharpener-93213.html
Hope this helps
Pete
Purchased 8/2010
Hope this helps
Pete
