Does anybody know if it is ok to switch between room temp mode and stove temp mode while the stove is running, or must it be shut down first?
So going through the off position quickly won't set it into shutdown ?Not a prob.
WOW, stove temp really throws out the heat and only on number 3. A little too over whelming for right now.
Yea Melissa, I am finding the same thing with mine. This is also my first year with a Harman, I have also had a Quad for 4 years.This is my first season, but I have tried the following:
Room Temp/Auto
Stove Temp/auto
Room Temp/Manual
With Room/Auto, the stove comes on only when needed.
With Stove/Auto I found my room temps to continue to rise over time because the temp focus was on the stove.
With Room/Manual, the fire will increase and decrease as needed to keep the room temp constant but not go out (unless you run out of pellets!) Running this mode I have found the room temps perhaps 2 - 3 degrees above what the stove is set at...at least for this time of year.
I was on stove temp auto and set at 3. I am now back to room temp auto.What mode are you in?
40,000 BTU. Guess I will need to try 1 or 2 in stove temp when it gets colder outside.Stove temp 3 will crank some heat. How many BTU's is the Accentra?
What ya wanna ask, which I like better?ok i gotta ask since you have the mt vernon too![]()
Well, it is really kinda early to tell, hasn't been really cold. But here is what I have so far. I like the burn pot of the Harman better, I think the Quads auto clean needs some rethinking. I also like that the Accentra has the low maint. burn option other than reaching temp and shutting down. I think the Quad allows for too much temp swings because of the shut down and auto cleans. That said, the Quad is a real work horse and puts out a lot of heat. I just find the Harman to be a lot less of a maintenance problem. I have had trouble in the past with hard clinker formations forming on the Quad pot floor and not opening or closing properly causing shut down. I have had to grind the floor with a Dremel tool a couple times a week. Once again it is really early but I think if I would have to buy another one at some point, it would be a Harman.yes, i was asking WITHOUT askingpros and cons would be nice too i like them, look nice
Didn't say it sucks, but I was being honest. I still will not part ways with it until she quits on me and hopefully that is a long time away. Gotta remember that I did originally choose that over the Harman when I first made a stove purchase. I won the Harman, or I wouldn't have that either.ya that mt vernon sucks, ill give ya $500 for it![]()
Yea, I know, she did heat my entire house for 4 years prior. That's why she will always have a home here.How many BTU's does the Quad put out?
I know, just razzing you back. When I first bought the Quad, I was looking for multi-fuel, I burned corn, and I don't like the looks of the PC45, I like the old cast look. Now I will have the P stove people mad at me.no man im not saying that, i was just joking trying to score a dealhonesty is always the best policy. i was going harman at first then enviro and settled on the quad because of dealer wait time for the harman and price i couldnt pass up the AE for 3200
I won it in Harmans pellet challenge, see this post. https://www.hearth.com/talk/threads/pellet-challenge-contest.85864/LOL all in good fundid you say you won the stove? hows that? nice
