Hi,
I have a new Hearthstone Heritage, that I have been operating for about 6 weeks now. I'm at 8500 feet, in a cold forested mountain canyon, in Northern NM near the Colorado border. I'm sitting here after cranking this darn stove all day, at a cool 59 degrees, about 15' from the stove.
This is going to be a detailed post - but my main two questions are going to be, should I take a bath financially and replace this stove with a larger, steel type stove that will CRANK the heat out. And if so, looking for advice on what to get for my situation. A large Lopi maybe?
I'm having problems keeping the Temps above 350 degrees - picture attached of my current Temp, mid afternoon, after feeding and messing with the stove ALL DAY and still under 400....... I'm having a problem heating my rammed earth home with it. I admittingly have a home that would be very tough for any wood stove - this is due to the 6' (that's SIX FEET) thick rammed earth wall on one side, a thick cold uninsulated stone floor on the bottom, and a 3' thick rammed earth wall on another side - meaning much of the heat from ANY wood stove is going to be sucked away into all this mass. To add to this equation, I have tons of glass on my south side which is great when the sun shines, not so great during cold cloudy weather.
However, my previous stove, was a small, less than a grand new cheapo steel stove, and it actually performed BETTER than this Heritage does. And this is after me spending nearly 4K with delivery and tax. OUCH!
I have read countless threads on this forum with other people with similar issues. Have tried a lot of their advice. Nothing has worked so far.
I'm not a new to wood stoves, I have lived with wood heat my entire life. I'm a total newbie to EPA soapstone type stoves.
All my wood is completely dry seasoned, verified WELL under 17% moisture - checked with a meter, although, like most folks who have been doing this for a while, I can pretty much tell seasoned wood by the look, feel, smell, sound, etc......
I have tried many different varieties of wood the past month, the typical woods of my area of the Southwest, Ponderosa, Aspen, Spruce, Fir, Cedar and the best local wood Pinon, - and my latest expense, I bought a cord of dry White Oak - which definitely increases the burn time, but has done nothing to help get this stove up to say 500 degrees, and stay there.
I have to laugh when I recall several people told me this Heritage would "cook me" out of my small home - around 800 square feet interior. I wish. Today we are having a record breaking, January type cold spell - temps supposed to fall below zero tonight, I have been carefully loading, and reloading all day, to try and keep the stove above 350. I'm struggling to keep this home above 60 degrees. I have tried seemingly every combination of the air lever, keeping the "dog house" clean, using small splits, getting it hot with door cracked first etc etc......nothing has worked for me yet.
So anyway, after 6 weeks of constant tweaking with this stove, I'm at my wits end, and just wondering if I made a huge error, in not getting a large Steel type stove that will CRANK out the heat - not this slow stuff mellow stuff I'm getting out of my Heritage.....
I so recall the wood stoves of my youth, pre-EPA, that would get blazingly hot, with any and all wood, and were a CINCH to operate compared to this Heritage which I have yet to figure out.
Thank you in advance for any thoughts, comments, or advice.
Best of luck.
I've had a Heritage stove for about eight years now and when we first got it it ran great. Then I replaced the ceramic baffle about two or three seasons ago and I thought I had some lame wood. After reading this thread I see that my baffle support is laying down. I had a fire last night (about 30 degrees here then) and the fire barely got above 350. Now I see why! Hopefully positioning the baffle upright will bring my stove back to where it should be. I will check it tomorrow night as it's supposed to be back down to 30 or so. Thanks for posting that.
