I'm on year two with a Hearthstone Mansfield and this morning when I went to reload it, a piece of the ceramic (from above the top baffles) was in the firebox. The stove is installed in front of a fireplace, and has a dedicated stainless chimney venting all the way up through the top of the stack (there's a cap on the ss chimney). There is a very good draft, so strong in fact that I had to install a stack damper. The stove got very hot for a short period of time the night before last, so my first question is: did the heat cause the ceramic to crack?
I'm burning very dry wood, and am having trouble keeping the stove in the "burn zone." With a full box of wood, unless I shut down both the stove damper, and the stack damper, all the way, just as soon as there are flames, the stove overheats, and quickly. This is somewhat of a pain in the neck, since I have to baby-sit the stove after re-loading. The night the stove overheated, I reloaded it (there was just a bed of coals left), opened the dampers, went upstairs to help my daughter with some homework, lost track of time, and by the time I came back down 25 or 30 minutes later, the stove thermometer was 700 and climbing). I also have a Phoenix, and can run that until I get a secondary burn going, and then damper it down.
Question two - is there anything I can do to better control the burn, or is this just the nature of my Mansfield Beast?
Questions three to ? - is the stove safe to use with a piece of the ceramic missing? Should I replace the entire ceramic plate, or cement the piece back in? Is it easy to repair or replace the ceramic? (And easy for me means under thirty minutes, with simple tools, and no need to lift more than say 30 pounds).
Thanks as always to all of you altruistic experts out there!
really?
