Hey Guys --
I can use some general advice on my new Hearthstone Shelburne. We have been using it now for about three days and I'm having trouble getting a hot burn out of the unit.
The Shelburne is replacing a 10-year-old Vermont Castings Resolute Acclaim 2490 that is in need of some serious rebuilding (I'm going to move it out to a shop . . .). That unit worked fine with my present triple wall stainless steel chimney system. I just pulled out the Vermont Castings and plugged-in that Hearthstone; everything lined up pretty well.
So, I'm a little perplexed why I can't seem to get the temperature up greater than about 430°F. Also, yesterday I put in some decent logs of locust and the unit burned through those in about two and half hours with the air setting at half. Last night I filled up the unit with some good would, turned the air control down to one quarter, and seven hours later we had a very small bed of coals.
I take it I should not be running this unit with the air control at minimum. And, if I do run it at a minimum, thus far I've learned that the temperature will drop down to about 100°F.
Does having the grate open or closed influence the burn? I take it not, if the pan is inserted snugly to prevent air flow.
Well, I don't think I have a done a good job describing my (non-existent?) problem(s). Maybe I'm just used to the previous stove, which we ran 24/7, and it'll take me a couple weeks to get used to the HearthStone. But, if anyone sees any familiar patterns described above, or can save me some time by sharing some hints regarding the best way to operate this unit, I would be most grateful.
By the way, I could probably offer somebody some help regarding the Vermont Castings Resolute Acclaim if they need any.
Thanks guys.
Thanks guys.
