Heat & Glo vs. Valor
Heidik
2
MT
Hello!
We are getting ready to purchase a gas insert for our living room upstairs. We are debating between a Heat n Glo GRAND-I35-SP and the Valor Legend g3.5/g4. Our insert size is 35" x 27" so it is a large opening.
When looking at both of the fireplaces, the heat n glo fireplace has a fan and we noticed that the Valor fireplace does not require one. We live in Montana and will be using this to heat the upstairs along with a gas furnace we have in our basement.
I am posting pictures of our living room area and the fireplace opening itself. We will be cutting the sheet rock around it and installing a cement backing along with tiles with a hearth when we get the insert complete.
Any recommendations out there on which is better? It seems to me we are in the same price range for both as we consider them.
Valor is a Cadillac fireplace. Great radiant heat. The blower is optional. In this case get it. You won't be disappointed with the fireplace. The turn down with the gas valve is second to none. Works great on milder days.
Sent from my SM-G930W8 using Tapatalk
Reactions: Heidik
If you're not planning on building a hearth get a four-sided surround. If you are planning on building a hearth get the Clearview front with the Vienna feet.
