I am getting quotes on installing a new 8 inch 25 foot insulated liner for my new Blaze King Ultra. I need to know the necessary components. It will be going through a 4 inch block wall and into and interior chimney. I want the thimble as close to the ceiling as possible.In this way I can get close to the 32 inch straight rise before any elbows that blaze king recommends. One guy said a chimney top, cap, flexi stainless steel pipe 25 foot and T connection for a clean out. He said the T would be open at the bottom so when swept that the debris would fall through the bottom opening of the T and fall to the bottom of the chimney and removed from the clean-out door. What connection or thimble should be used ? I have seen other posts about a block-off plate ? What is this and do I need one ? Anything else I should know? I want to do it once and right the first and only time.
Should I get ridged or flexi . Some advise on the straight ridge others have said there are more seams that may leak or loosen. Some say the flexi is harder to clean and the rigid clean easier and get cleaner. Thanks
