I think you should try it without the cap on once.yea I thought so too.. but thats what you get if you buy at lowes.
I read this thread earlier, came back to ask about the outside air or lack of it. By your answer I am guessing you did not install it, correct? A short chimney, no outside air and possibly wet wood all togeather add up poorly. Direct Connection to combustion air without the need for extra draft suction really helps if you have draft issues already.Is it possible that your house is too tight
Excellent question. I read about this too. but unfortunately an open window just makes me colder lol
Those secondary burn tubes should be rolling flames when the damper rod is shut. If it's not producing any flames from those tubes than I bet the wood isn't dry enough.Is it possible that your house is too tight
In that video you push that rod in which I assume is the damper. Are you supposed to shut it all the way?
No not typically, I just wanted to show there was no difference from fully shut/open
Does that stove have secondary burn tubes?
Yes it does
I am sorry but when we see some very obvious and very serious safety issues they need to be pointed out. I personally would not even work on that stove the way it is set up if i was called to your house. It is dangerous. Fix the clearance issues.So refreshing to hear, especially after hearing how unsafe I'm apparently being. I'm trying to do the best I can with the conditions I have.
![[Hearth.com] Help please, before i freeze to death [Hearth.com] Help please, before i freeze to death](https://www.hearth.com/talk/data/attachments/164/164432-78d426644ad004f998dc0f78b2632470.jpg?hash=4JpzjsnUa9)
If not I'm going to have a hard time finding wood this year because this is what everyone is selling.
