Need some help guys. I'm in my second season of burning with my Hampton HI300 and have a 28ft exterior chimney with an insulated liner. Since I've been burning with this insert I have ALWAYS had a strong draft like a jet engine
Matter of fact I have never even felt cool air in the firebox during frigid temps in the dead of winter last season. All I had to ever do is build a top down fire with some rolled newspaper on top and whoosh...away it would go, burning great. I did have a block off plate installed in September but every fire I have had this season has been the same...whoosh and it's burning like a champ!
So tonight I came in from work and it's about 40 degrees and rainy...so I figured I'd light a fire. When loading the firebox I noticed cool air coming into the firebox something I haven't noticed before since I've been burning? So I went ahead anyway (I guess like a knuckle head) and lit the paper. The paper didn't light up with whoosh as usual but started to smolder and the firebox filled with smoke and started coming out from behind the door and from the intake vents at the bottom. So I closed the air down and open the sliding door near the insert, but nothing changed as I watched is smolder.
For some reason I seemed to have a very strong down draft that I have never had before?? It kind of freaked me out as this insert and chimney set up have ALWAYS been like a jet engine when it comes to the up draft? The dealer installed a new cap/bird cage on top of the chimney when they installed the insert a year and a half ago so I can't imagine an animal or something got into the flu pipe? It can't be the block off plate as every fire this season has been like a jet engine? Any feedback would be greatly appreciated!
Matter of fact I have never even felt cool air in the firebox during frigid temps in the dead of winter last season. All I had to ever do is build a top down fire with some rolled newspaper on top and whoosh...away it would go, burning great. I did have a block off plate installed in September but every fire I have had this season has been the same...whoosh and it's burning like a champ!So tonight I came in from work and it's about 40 degrees and rainy...so I figured I'd light a fire. When loading the firebox I noticed cool air coming into the firebox something I haven't noticed before since I've been burning? So I went ahead anyway (I guess like a knuckle head) and lit the paper. The paper didn't light up with whoosh as usual but started to smolder and the firebox filled with smoke and started coming out from behind the door and from the intake vents at the bottom. So I closed the air down and open the sliding door near the insert, but nothing changed as I watched is smolder.
Even matches didnt stay lit for long.....Anyway, opened up a window, left the door slightly open and set fire to a big pile of paper....that did the trick.
and a wife stumbling out saying "what the..."
