So I'm new to the forum and a couple years deep into wood stove burning. This may be long winded so I do apologize but the more info I give you, the better you may be able to help me. I have a exterior fireplace (16ft) that I installed a vogelzang colonial insert a couple years ago. The thing was great but just didn't have the burn time to keep the house warm through the night without reloading multiple times 10pm and after... I got a great deal on a slightly used VC Montpelier, just needed a new baffle and a couple cosmetic upgrades to please the wife. Got it all hooked up this past Friday after work and did the small fires for break in since it had been sitting in my cooks garage a few weeks. The weather was warmer than normal so during the break in fires and couple larger after that I was getting great heat in the living room where the stove is located and upstairs bedrooms! Even the playroom down 3 steps off the living room wss getting warm and it never did that with my old stove... by the way I have a split level house with a open floor plan between the living room and kitchen (no interior dividing walls just exterior walls) 3 steps down to a playroom, bath, basement and garage. Also 10 steps up off the living room that goes up to the 3 bedrooms and 1 bath.
My problem seems to be that no matter how long I keep the door cracked when starting a fire and having a good bed of hot coals, no matter how much or what size or direction of wood I can't get the secondaries going???? Maybe just a little on the back tube for a short period of time. I've only been able to get the stove up to 400 once other than that is been 300-350 by the thermometer I have in the arc of the door. I went and bought a box of kiln dried wood even though I've checked my regular burning wood with a moisture meter and it's all under 20%. The liner is insulated. I DON'T have a block off plate (that's next) but I did put a bunch of Roxul around the top of the liner on the roof at the cap when I cleaned the liner before install. I have Roxul around sides and back of stove to keep it warmer in the exterior fireplace. New glass and door gasket that kinda passes the dollar bill test, I think my hinges are done so I have new ones on the way and the spacers... checked with both a lighter and incense for air leaks around the door and connections for liner and collar, all are good..... WHERE AM I GOING WRONG or WHAT AM I MISSING??? And the glass is NOT getting really dirty or black so I'm lost
Oh yeah don't know if it's the stove or my draft but it doesn't seem like I have as much as a roaring flame in the beginning like my old smaller stove or like it sounds like some people are describing on posts rust I've seen. I mean it gets up there but not crazy.... thanks in advance for any helping hints or ideas
The wood dries from the outside in. That's why the need to resplit for a check. Let the split warm up to room temp first.
. Just trying to figure everything out before I sell my old stove. I would kick myself in the ass if I sold it then find out that something was messed up with this one. I'm sure I could and would fix it if that were the case but you get my point. The only things I changed when I installed the new stove is the Roxul up top around the liner under the cap and the half assed block off plate that I had made from the extra insulation for the liner is no longer in place. I took it out because I planned on making a proper block off but soon realized that wasn't happening with the stove in the fireplace and my helper was gone at the point. Think I'm going to pull it out this weekend and make the plate and also adding a piece of 1 3/4 sandstone under the stove in the fireplace because my surround falls a little short on top meeting the stone wall, hopefully that helps a little with the draft and ill split and check my wood when I get home. If needed ill go get a pallet of kiln dried.
I think a little might have leaked down my leg lol. Anyway installed the new fan and keeping the original for back up.
