Ok, so my 1995 Sierra Products Easy Fire 5000 cuts off after sometime and the overheat light comes on.
After cool down, it'll start right up.
If I reduce the feed rate to to about 65% of max itll stay light for much longer, even through the night some times, other times it'll cut off after several hours.
I have cleaned the stove and flue / chimney pipe.
I have swapped the two newer sensors ( problem persisted)
I have replaced the motor, combustion and convection fan ( it was noises and vibrating anyway)
Thinking it must be the main motherboard
There is a short section of pipe from the exhaust manifold to the rear of the stove / glue pipe that is not accessable. I tried blowing it with my leaf blower.
I quess I can remove the flue pipe off the rear of the stove and check for obstruction ( but I think this is unlikely)
Also if the pipe was obstructed this should trigger the blocked flue light ( hasn't happened)
The manufacturer has been slow to respond to email.
Does any one know what a general overheat temperature would be? 250F?
Trying to figure out if I am really overheating or if the problem is sensor / computer in origin?
Any thought on disassembling pipe to check for obstruction is it pretty easy to reinstall?
