I recently purchased a High Valley 2500 stove and this is my first stove. Growing up my parents had a stove but that is my only experience. The issue is that the stove is not burning hot and the fire seems to die when i close the door. If the door is cracked, the fire flames up and there seems to be plenty of air. Could there be a blockage in the intake? More info as follows:
The wood I am burning was cut 2 months ago - I tried burning wood that has been seasoned for 2 years and did not show much improvement
The stove was installed by basically placing it into my existing fireplace and attached the siding
The chimney is a double flue with a fireplace on the other side of the wall.
I was really hoping this unit would be as least as effective as the big buck i grew up with but so far it will not even heat the tiny room it is in, much less the house...
I think this stove is similar to the Buck 91 that I run at my MIL's house, so yeah, it should toss big heat. Did you install the stove yourself? Is there a stainless liner all the way to the top of the masonry chimney? How tall? Any pics you can get may be useful....
