- Sep 28, 2006
- 24
Do to my work I can't burn 24/7. But I do burn everyday while I'm Home. I was wandering if it is ok to get a stove hot and then cold over and over everyday. On the weekends I do burn all day and night.
Rhonemas said:If your stove is steel, the constant heating and cooling makes it stronger. It's called tempering, like Samurai swords are repeatedly heated and cooled to make them stronger.
That's how I'm using mine even if I'm home. When I light a fire if it's 25F+ outside I'll raise the temp of my house anywhere from 10-14F at the minimum load, minimum air setting I can set (big insert in a small house). So, I pretty much light a fire on an as needed basis, maintaining it 24/7 I'll overheat the house. When it's 0F or less outside that's when I can just about have a fire going 24/7, loading it up every 8 hours.
Marty S said:May I make a correction?
"Tempering" metal is heating it to some critical temperature, usually red hot, followed by rapid cooling to fix it in a hardened state.
"Annealing" metal is likewise heating it to a critical temperature followed by slow cooling thus giving the metal a soft layered crystalline structure which improves its machinability and cold working properties.
Either of these terms may not be directly applicable to wood burning metal stoves. Probably, some of each occurs. Regardless, the cyclic heating/cooling of wood fired metal stoves is called "thermal cycling" which has a destructive affect on the stove and, eventually, makes it and/or its components wear out.
So, by firing your metal stove, you are, sadly but surely, contributing to its eventual demise (not helping it get "stronger").
Aye,
Marty
Grandma used to say, "The devil is in the details."
Andre B. said:Marty S said:May I make a correction?
Aye,
Marty
May I correct your correction?
All of these are known as heat treating processes.
Hardening: is a heat treating process to make the metal fully hard, you cannot normally, accurately take metal up to a certain hardness its all or nothing and the metal is often very brittle at this point.
Tempering: is taking fully hardened metal down to the hardness you want, making it hard enough to do the job while not so brittle it breaks.
Annealing: is tempering to the point the metal is as soft as it can get.
Stress reliving: is controlled heating and cooling for the purpose of relieving stresses put into the metal from casting, welding, forming, etc.. This makes the metal more predictable and less likely to fail in use. I would say tougher rather then stronger but both words work.
Continued "thermal cycling" can be destructive but it is exponential with the temperature, normal low temp cycling can go on for a very long time with little effect while higher temperatures have an effect much sooner. Also the speed with which the temperature changes and how evenly the part is heated have a big impact.
Marty S said:Thank you. But, don't stop now you have my attention...
So, which of these heating "treatments" apply to a wood/coal/pellet/corn/dung burning metal stove and to what extent?
Eah,
marty
greenergrass said:Do to my work I can't burn 24/7. But I do burn everyday while I'm Home. I was wandering if it is ok to get a stove hot and then cold over and over everyday. On the weekends I do burn all day and night.
Andre B. said:Marty S said:Thank you. But, don't stop now you have my attention...
Eah,
marty
Not sure which direction this is headed. :gulp:
Marty S said:Have you an applicable contribution or were you merely spewing out some quasi relative rat facts?
Eah,
Marty
ROFLMAOhomefire said:greenergrass said:Do to my work I can't burn 24/7. But I do burn everyday while I'm Home. I was wandering if it is ok to get a stove hot and then cold over and over everyday. On the weekends I do burn all day and night.
My God man ,
You mean your intentionally lighting fires in your
wood stove?
Andre B. said:Marty S said:Have you an applicable contribution or were you merely spewing out some quasi relative rat facts?
Eah,
Marty
That's where I though it was headed.
Tempering does not make the steel harder, quite the opposite in fact.
http://www.efunda.com/processes/heat_treat/introduction/heat_treatments.cfm
