We're adding insulation through a state run program in Massachusetts, providing a 75% reduction in costs up to $4000 annually. Not sure who is behind it, the state or the power companies...
Anyway, due to a variety of issues, what should have been a one day visit has turned into a two day + job.
On day one, the team did all the top sealing in the attic, put an insulated box above the attic pull down steps, and applied some 2" rigid board to about 200 sq feet of exposed wall in two attic areas. These walls are 2x4, insulated with fiberglass batting, and have some exposed outer surfaces in an unheated area. They also changed two bathroom vent hoses for insulated hoses.
They could not blow cellulse in before the HRV is installed. I thought they were going to install the HRV...turns out they won't... Oh well.
So I'm having a heating guy run the ducting for the HRV, then the insulation company will come back and blow 6" of cellulose throughout the attic and run R30 fiberglass batting on the exposed portion of the cathedral ceilings. They will also blow some insulation into an exterior garage wall that sounds suspiciously hollow.
I was interested to find that the upstairs hallway seemed a lot less drafty after just the topsealing. Some of this is probably due to the previously very poorly sealed attic pull down steps. I'm looking forward to seeing the impact of the cellulose on top of the work already done!
