I know this must sound silly, but when you install a liner, how do you connect the black pipe from a stove to the stainless steel "snout" coming through the thimble?
With my old terra cotta and masonry flue and thimble, I would just slide the black pipe all the way into the thimble and use a little furnace cement to seal any gaps. I'm getting ready to install a 6-inch stainless liner, so I'm test fitting everything before I try to install it. I discovered today that my Ventis single wall pipe section won't fit over the snout coming from the liner.
I bought the liner and the black pipe from Rockford Chimney Supply. When I called them for help, the rep said I was the only person he'd talked to in 3 years who'd had a problem with this. So... I'm sure I'm missing something obvious, but how do other people connect their black pipe to their liners?
