E
elkimmeg
Guest
velvetfoot said:elk, do you have any idea how much makeup water your system uses?
Here what I did I set up a manifold with a series of ball valves to isolate complete zones and I connected a draw off valve fawcet
First of all I drained the entire system then with an air compressor blew out as much water as possible Next I went to Wall mart and bought 15 gallons of RV antifreeze
withan electric pump and a double end washermachine hoes I attached the pump to the open draw off valve on the other side I connected another hose that lead back to the 5 gallon bucked that pad the pump in. I poured in a few gallons of antifreeze and plugged in the pump filled the system and the over flow came out the other return hose back into the pump bucket I ran it a bit longer which with the return hose below the fluid level it becomes a closed system and all air id bleed out I closed the ball valves and repeated the process to all zones (3 in my case)
Total anti freeze about 5 gallons per zone The way I setup mu manifold made it easy now if I work a zone I have total isolation and do not require a total system bleeding.
Yess it requires soldering and installing valves but drawoff should be present on your original setup . I also installed a ball valve breeded to make it even easier Later I should supply pictires ov what I setup Total time to drain the boiler and zones and charge them 30 minutes once everything was set up. This is the smartest thing I have done gone are the days waking up at night trying to find freezeups gone are the days of the water fall sounds in my walls Gone is the guess work did I bleed all the air out. Finally after all the years doing my own boiler service I hired a tune up and clean out. Really I wanted a second oppinion of my boiler's condition. the burner tech commented it was the best setup he has seen as far as zone isolation and being able to work on indivual zones. Because from day one wood heat this burner is in great shape It never saw full demand full time. The technition did everything I did but Changed the electrode gap to larger fro a hotter spark my 1977 Unica Boiler tested out to 81% effeciency highest it ever tested normal was 78% Another thing is a motorized daper I added on years back.
what this does is hold the heat longer in the fire box instead of it escaping up the chimney. Just before the ignition it opens exhaust the gasses then is closed no heat from the fire box excapes up the chimney Thgis reduces the cycle times to bring the fire box back to temp. No wind flapping the Baro damper drawing the heat out of the fire box. It does have to be wired into the thermostats to receive the demand to open if it does not open there is no ignition. Delay timing can be set for the oil spray to also increas ignition effeciency.
Warning if you are have oil boiler problems DO NOT USE THE RESET BUTTON MORE THAN ONCE. IF IT DOES NOT FIRE WAIT AT LEAST AN HOUR BEFORE HITTING THE RESET BUTTON AGAIN. IF YOU HIT IT CONTINUEOUSLY YOU WILL CREATE A LOT OF EXTRA OIL VAPOR IN THAT FIRE BOX. SHOULD IT IGNITE YOU COULD HAVE QUITE AN EXPLOSION
