Here's a bit of info on regulating humidity levels in the house, shamelessly stolen from
http://www.woodheat.org
Do wood stoves dry out houses in winter?
My wife and I are thinking of switching to a woodstove in our log house but I'm concerned about the inside of the house becoming too dry. I've heard stories about people with wood stoves whose furniture won't stay together and the woodwork splitting. A childhood friend's father used to put a pot of water on top of the woodstove to keep the air humidified. What's the real truth?
Cliff
Hi Cliff,
Wood stoves are not specifically implicated, but do exhaust air from the house and this air must be replaced with air from outdoors, which in cold winter weather, is dry. Hence the theory that wood stoves dry out houses. Wood stoves are no different from oil or gas furnaces or any other device that removes air from the house. But a wood stove uses very little air; about the same amount as an inefficient bathroom fan. Compared to baseboard electric systems, yes they do contribute to lowering humidity, but not compared to all other options.
The real cause of low winter humidity in houses is leakiness of the house. Here's proof - new, tightly constructed houses need active ventilation systems in winter to control the build up of humidity produced by cooking, washing and breathing. Without active ventilation, the windows of a tight new house would mist up and run with condensed water vapor.
So, in old houses we humidify, and in new houses we dehumidify. All this has little to do with the heating system, except that a wood stove in a house does constitute part of the ventilation system. If you want higher humidity in your house in winter, spend some time and money on weatherization. On the other hand, there is no way you will ever get a log house tight enough to need active ventilation to control moisture.
