I clean the ash pan, burn pot and surrounding area of my stove every 2-3 days. how often should I clean behind the brick? I've burnt about a ton of pellets.
davevassar said:I clean the ash pan, burn pot
Kenny said:I give the pot a scrape whenever putting in pellets. Give the glass a little wipe while the door is open. Do the full cleaning every ton.
Keeping the stove clean (burn pot and heat exchanger) will only help efficency, and get more heat from the pellets into the home.
Cheers
Kenny
jed12674 said:I usually get about a cup to a cup and a half of ashes when I clean the tee. My pipe goes straight up from the back of the stove so that maybe why I get that much. That and the pellets I was using produced alot of fly ash.
jed12674 said:I heard a rumor that the company that make them pellets were experimenting by adding switch grass or saw grass into the pellet mix. I read that the switch grass or saw grass will cause a hard ash build up and produce a lot of fly ash. I have just changed to a different brand of pellets and there is still fly ash but not as much as the other brand.
