I don't trust moisture meters
Enzo's Dad
345
Canton, CT
This was a reading from wood in my wood shed since last July. I split 4 pieces and got the same readings. [Hearth.com] I don't trust moisture meters
Took it from the top row....has been in the sun alot
Fresh cut ash usually is low 30s to high 30s for moisture content.
That's exactly the same MM as I have. I did the palm thing reading these posts and mine was 30.2. I'm guessing I/we need some more seasoning! !!!
I do think it is fairly accurate.
Reactions: Wisneaky
I have some ash, cut in January, split to 4-5" in April and it's 14%. The dead elm I pulled out of a ditch this spring will wait till next year.
If the splits feel fairly light, burn it! ==c
Up at the top of a covered woodshed, ash, 12+ months, that doesn't surprise me one bit. It would surprise me if the splits on the bottom were as dry. I started stacking mine right up to the metal roof after I discovered this phenomenon. I wish my shed was all roof... Everything up there is probably golden.
A year and 2 months.....ash
That seems right to me. I split some Ash in late July last year and my MM (same as yours) had it between 19 and 21% in November. It was split small and stacked loosely in a favorable area but Ash dries quickly in my experience. BTW... Great stack!
Yep. Last year I thought I had a stack of 18% oak in only 1 year. Turns out the top two courses were but as you picked down it got much much higher!
A friend of mine who supplies me with green rounds started selling split wood. He was advertising 13% moisture content based on a piece he measured after 9 months on top of the stack! I quickly let him know he needed to check a fresh split! He was a bit bummed when the wood was still high 20's.
Reactions: Soundchasm
I got the same meter, I had some cherry last year that was split and stacked for (3) years, it registered 11%, I thought the meter was playing games until I through the splits in my old stove, It was like burning newspaper. I also with the same meter hit some oak that was (2) years old and it kept registering 26%, I thought it was high, I threw a couple splits and had the boiling steam effect come out the end grain. I trust my meter.
The key to using it properly is just like in your photo, fresh split face, find the grain length and put the probes in parallel.
Reactions: Wisneaky
