ICC Ultrablack 8" CRACKING WELDS - Blaze King - King 40
JuneauAlaskaBurner
6
Juneau, Alaska
I've been burning my new King 40 wood stove since Fall of 2025 and love it. I have a long vertical 8" I.D. chimney. About 14 ft. of ICC ultrablack and then the ICC Excel through the attic and out the roof. So almost 30 ft. of chimney total up to the deluxe cap.
I'll admit my Spruce & Hemlock wood is not completely seasoned and that may be my main problem. But I have cracked the inner laser welds of my ICC ultrablack sections multiple times now and end up with liquid creosote running down the outside of the ultrablack.
It is 99% humid in Juneau most of the time so it's tough so get my firewood super dry. I'm mostly burning soft woods (Spruce and Hemlock). Very little hardwoods available here.
The King40 burns great and the catalytic combustor appears to still be nice and clean at this time. My cat thermometer is always well into the active zone. I think what's happening is since my chimney is so tall, I'm inevitably getting condensation & liquid creosote on the inside, most likely 20 ft. up the pipe but probably varies depending on how hot I'm running the stove. The first time I cracked the welds there was very little creosote on the inside liner when I took it apart. Just some black dust basically.
Any suggestions or ideas aside from only burning super dry wood? I know Spruce is a very sappy wood and creates a lot of creosote - but it's what I have. It would be great if I could go 4 or 5 years between cracking these lame welds. It's hard to believe a little creosote liquid could eat up a stainless-steel weld in less than a year. The cracking welds are literally the only problem I'm having. Aside from cracking the welds I have no other issues at all from burning the less than perfectly dry soft wood.
I'm going to take my UltraBlack chimney sections apart this weekend and can upload photos of what I find. Maybe I just need to get a different stove with no cat.
Thanks - Austin
Do you have a flue probe thermometer?
The only two solutions (if it's not bad pipe) I see are 1. decreasing the amount of water you pump up the flue (you already mentioned that, so no sense in hammering that in more imo), or 2. keep the temperature in the flue high enough *all the way up to he top of your very tall stack*.
A flue thermometer will help with that.
However, I also think you may be over drafting - at 30 ft (if no flue damper is present), you are certainly having too much draft, outside specs for a BK.
Normally, however, that would lead to too much heat being sucked up the flue - a bit inconsistent with the suggestion to keep the flue warm enough, maybe.
It's also tough to estimate what temp you need to see 18" above the stove, to be above 250 at the top of the 30 ft...
I may be wrong but I think ICC comes with a lifetime warranty.
I do not have a flue probe thermometer. But I agree it would be tough to determine the temp in the upper end of the flue. I use my infrared thermometer pretty often and am normally between 375 and 500 degrees near the cat thermometer on top of the stove. The whole point of the big blaze king with the cat is to be able to run it kind of medium low to extend burn times. So I’d rather not have to run it near wide open all the time. I’ve attached some photos of when I took it apart yesterday. I had enough sections of unbroken pipe to piece it back together and use the stove. I don’t see any corrosion on the inner stainless sleeve. But the welds are broken clean. . I’m thinking of having my welder buddy lay some additional welds maybe a foot in from all pipe ends on my next batch.. I don’t appear to have excessive creosote build up. I’d imagine I’m only getting the liquid creosote occurring for a little while at the beginning of a new load of wood. But I could also be getting it when running the stove too low. Like I said the stove runs awesome.
  • [Hearth.com] ICC Ultrablack 8" CRACKING WELDS - Blaze King - King 40
Is it even welded at that seam or is it just overlapped? If it was welded It’s a ICC quality problem, not even remotely a BK running low issue. Any pipe should be able to handle that all winter long.
What I see in the pipe looks reasonable. Not shiny etc.
It could be a case of the leak letting in cold air, and that is creating the creosote.
Reactions: JuneauAlaskaBurner
Yeah from what I understand it’s a laser weld. No overlap at all the metal meets flush where the welds are. ICC kindly sent me free replacement pipe last time although I paid the barge freight bill to Alaska. The rep did say they would warranty them again but only one more time. They insisted it was the acidic creosote liquid attacking the weld joint. And that I shouldn’t have any liquid creosote if I was burning correctly and using dry wood. And that I was burning too low and slow. I am just bummed that the weld keeps breaking when the rest of the liner is perfectly fine. I think they need to improve how these are welded if they intend people to use them for wood stoves in varying climates. They aren’t even surviving one burn season.
But liquid creosote can be made where air leaks in ( due to the crack) because that cools down the temperature of the smoke.
The pipe pics don't show liquid creosote formation as all is dry, dull, powdery, it seems
If your pipe would show shiny creosote everywhere, they might be right. But from the pics it seems to me that the creosote is a consequence of the cracks, not a cause.
So this pipe is not air tight, it isn't supposed to be and doesn't have to be but the pipes should connect in a dripless fashion so that any liquid runs down into the stove.
What does the new pipe look like? Is there an overlap, can you pull the overlap apart as you can with your broken pipe? With no visible corrosion anywhere and just a failed weld this is a manufacturer defect.
How did you even know that this problem exists? Visible liquid tar pouring out? It's double wall so where did you see it?
BTW, the current RH in Juneau is 86%. 91% at my location in washington. Humidity is no excuse for your inability to get dry wood. Juneau average annual RH is 82%, 80% in my location in WA. My fuel tests in the 15% range whether that is evergreens or our hardwoods. You just need to get ahead and store the wood to dry it more but in the end all fuel has water in it, your flue system should be able to handle it.
Yeah I agree with you. You can search the ICC Ultrablack on google and see what the brand new pipes look like. They are an air-insulated double wall pipe. Definitely need to get ahead on storing firewood for the long term. My wood has been testing between 17 and 20% on average. I only notice the problem when liquid creosote runs down the outside of the pipe - indicating the section above the leak has broken its weld. They are all lapped correctly and work great until the welds break after a few months of steady burning.
but @Highbeam I think the creosote is the result (not the cause) of the cracked weld. Let in cold air, and you'll get shiny creosote. (Don't ask me how I know...).
I think the weld cracked, and that created the creosote due to the mixing in of cold air, and that ran down/out of the pipe leading it to be observed.
17-20% wood is fine.
Reactions: Tron
@JuneauAlaskaBurner
No offense but.......
Why are you re-installing more of this product? It apparently doesn't work in your application. Seems like a great opportunity to try another brand.
Believe I'd swallow my pride/investment and move on.
Purely considering the safety factor of multiple connector pipe failures!
Dunno. A thought. Good luck!
Reactions: R-Ogre and Tron
In my mind, liquid goo running down the outside of the pipe is not the same thing as creosote accumulation in a chimney. I don't even think that one can cause the other. If the inner liner is supposed to be welded and it's not then we have a manufacturing defect. Even if that defect is made more likely to fail in this particular installation, the stove pipe should not fail in any normal installation. It's supposed to withstand chimney fires!
17-20 is within the recommended fuel moisture range called for in the owners manual. Assuming you are checking correctly on a 70 degree fresh split.
Reactions: stoveliker and Tron
I agree it's likely a mfg defect.
I do think that when the inner pipe is compromised, goo can run out.
I had a bad connection between pipe and thimble. That ran horizontal but I could see a puddle of shiny goo right there when I opened it up.
Reactions: Highbeam
