ICF = Insulated Concrete Forms. I built my 1st house out of this. They are two styrofoam panels - one inside the house and one outside. They pour concrete (4"-6") in the middle. The brand I used gave me an R-32 wall. The wall goes from the footer to the roof. The roof (cathedral) I put 3" of rubber roof blackboard insulation then sprayed it with 3" of spray foam. It is 2,050 sft plus a heated 1,200 sft basement.
The result is a very tight, well insulated house. At the time (2000) the cost to do build the ICF labor myself was the same as hiring a builder to stick frame the house.
I heat with oil and used 500-600 gallons per year (3,250 sft total) keeping the house in the low 70's. You guys will be happy the new owner is in the process of putting in a OWB, although I can't get him to read this board! My oil delivery guy asked me if I was getting oil from another guy because I was using so little oil. That was when I knew the ICF walls worked!
It's expensive, but something that should be considered for new home construction.
I used Reward Wall brand name, but there are many other kinds out there. For all I can tell, they are all basically the same.
