If you had to own a VC defiant....
kentuckydiesel
25
If you had to own a VC Defiant, which model would you go with? Are the 1910/1945 better or worse than the newer ones? Is it possible to make a 1610 operate correctly? Any other thoughts are appreciated.
Thanks,
Phillip
The older ones had less robust refractory components. The new ones are more complex to service. The original was the most robust and easiest to service.
Me personally I'd go with a newer model.
I have the 2040 encore and it's been my primary heat since installation. I burn roughly 3/3.5 cords per year. 10 hour burns every night with no issues. My longest burn being over 14 hours on 1 load. The stove shines in it's low burn output. It cranks out serious heat at mid to 3/4 air.
Yes you'll be replacing cats and refractory every so often, but I knew this going in so it doesn't bother me. Some feel you really shouldn't have to maintain a stove. That's fine for them. Me I don't care. It's a beautiful stove and heats well.
The key for this kind of stove is draft. Get your draft right from the beginning. Read the manual understand what it's telling you regarding height and clearance.
You need dry wood. FOR ANY STOVE. That being said this stove runs the best with dry wood sub 20%MC
I would agree with a newer model but I would not go with a Defiant. There is definitely a learning curve with a new stove but slightly more with a new VC stove (my opinion). I have had a Defiant for a few years and the increased size and capacity didn't seemed to be met with an increase capacity of certain design features. I believe this is what causes such a heartache with operating it within range and not overheating it regularly. If I could go back I would probably opt for the Encore (or another brand entirely).
After saying all that, there is a chance I am inept at running my VC Defiant. I am not arrogant enough to believe a level ignorance couldn't exist in my ability to operate my Defiant efficiently.
  • Haha
Reactions: arnermd
