Our stove worked fine all weekend with the below zero wind chills.
woke up this morning and turned the thermostat down about 2 degrees.
old man filled the pellet hopper. pulled the cleaning rods.
I came in to the house smelling like smoke.
It is flashing the #2 error code on the panel which is one of the following:
a. door open longer than 60 seconds - NO
b. ash pan door open longer than 60 seconds - NO
c. combustion fan not running (defective fan or control board) - how do I tell?
d. vacuum switch defective - how do I tell?
e. vacuum hose disconected - NO, disconnected blew it out and reconnected.
f. vent system plugged with fly ash - NO, we took it all apart and cleaned, vacuumed and leaf blowered
I also cleaned everything, took the ceramic brick out and cleaned.
We tried to get the room blower fans out but could not so brought an air compressor in and blew the crap out of them.
blew out the other fan the same way. hit the high temp reset switch.
I give up. I just don't understand why it quit working.
