So, as usual with most things that I do, this has been an ongoing work in progress for a while. I have been trying to figure out the best way to try to automate control of my intake air damper to increase the overall burn efficiency. I figured I could use a PID controller and proportional damper actuator to try to maintain a constant flue temp. I tried doing this at first with a thermocouple installed in the stove pipe, which improved things a bit but still wasn't providing adequate control. I then installed a thermocouple directly behind the cat's and have found this to provide a lot better control. Now, once I'm certain the cat's (there are two of them in my boiler) have lit off I no longer have to make any additional damper adjustments and have found that I'm burning much cleaner and generally heating the house much easier. I call it my full time fire tender.
As you can see in the pictures, I have a tendency to leave things in a state of disorder. I always hook things up temporarily to try to figure out how it works and then fail to go back and clean things up like I had planned.
![[Hearth.com] Improved my burn control [Hearth.com] Improved my burn control](https://www.hearth.com/talk/data/attachments/126/126766-58561fed64e73b9950042d2faab3c1fa.jpg?hash=eEXt4VUNQ0)
![[Hearth.com] Improved my burn control [Hearth.com] Improved my burn control](https://www.hearth.com/talk/data/attachments/126/126767-cd10b4898adc0429a4ea6892d6ef0438.jpg?hash=_EH1hkNr_H)
