Insulation around my insert - Safe?
BurningBrutus
135
Amherst, NY
Hi, on my Pacific Energy Super insert i wanted to put Roxul on the sides and behind it. I have about 2-3 inch's behind and about 2 inch's to a flair out on the sides. Is it safe if the Roxul is tight and touching the stove walls behind and on the sides. Please see pics. Thanks for the help.
  • [Hearth.com] Insulation around my insert - Safe?
Yes, i forgot to mention it is installed in a zero clearance fireplace, i know, i know.
Ask PE i would tell you to ask the fireplace manufacturer to but i doubt they will give you any advice other that not to put an insert in their unit.
Roxul itself is good to over 2000ºF. Touching should not be a problem for the Roxul but I have no idea if that means it is not a problem for your insert. They make assumptions about how well the insert loses heat.
