Is candle wax flammable when it spills on a wood stove insert?
Carrieleigh
3
Pennslyvania
I left a pillar candle on my wood stove insert and it melted down the sides and also on the top of the unit where I can't access. (There is a 1/2 inch gap between the top of the firebox and the top of the whole unit. It now has wax in it that I can't reach.) I've cleaned off everything I can, but there is intense smoke when I use the stove--so I know there's still wax.
My chimney repair guy said I should just let it burn off, but is that a fire hazard?
I appreciate any thoughts, ideas, or suggestions!
Yes it is flammable but i would still run it. But i would keep an eye on it when you do till the wax burns off. And have a fire extinguisher handy. I doubt it will be an issue but you should be prepared if it is.
I would burn the stove while I am there to watch it. Even if it does catch on fire, just let it burn, everything directly around it should be non-flammable . You cant be talking about more than a tablespoon of wax left that you could not clean up. I might even be tempted to burn out the wax with a propane torch.
I can't tell you what your results may be but I have spilled wax (from a tart warmer) on my stove with no ill effects other than the discoloration on the stove top.
