I got it installed, feeding it it's own shipping crate tonight...... pics to follow.
i was planning on getting the cat active and then turning it way down. Finding a good book and hangin with the stove.......That cat will be really active for a few days..scary active sometimes.
Knowing what I know now I would build small fires for a few days. Break the cat in slow. Good for the paint also to do that.
Perfect..just try to not load her way up for a few days. A lot of off gassing on a new cat really drives the cat's temp way up.i was planning on getting the cat active and then turning it way down. Finding a good book and hangin with the stove.......
That sounds great, but maybe you should post some pics before you get too comfortable.i was planning on getting the cat active and then turning it way down. Finding a good book and hangin with the stove.......
The man cave is the garage with the bikes..Looks like you could build a man-cave around that!
Normally stoves in garages are against code. Is your region an exception?
Prolly be fine if you do that,at least most of the time since you are in PA. .not that it can't get cold there!900sf upstairs in a rancher. I'll be insulating before next winter
How far did the cat probe get to?So far I am really impressed. With the old stove a full load of pine pallet would have over-fired almost immediately. The BK just took it in stride. I slowly raised the temp and in a bout 3 hours watched all the paint flash over and cure.I found the sweet spot on the damper too, sitting pretty with a 450° stove top right now and going to bed.....with some windows open cus its only 45° here now.......
It almost pegged in the 2nd hr but I was watching closely and dialed it back.
