Hey, Brian. I found this one for you on my first try:
(broken link removed to http://www.kschimney.com/store/product.php?pid=210)
Battenkiller said:Hey, Brian. I found this one for you on my first try:
EDIT: apparently you meant pretty locally too - just found out where K's is. But thanks, if I strike out locally I'll be ordering one online! I'm a man, so instant gratification is something I war against.
I'd HATE to wait days for something to ship; like a child on Christmas morning.BeGreen said:Waiting in this case is a good thing. Take advantage of the time to learn more about the stove. The more you know about how it behaves under varying conditions without the damper the better. It will help guide you about the effect of using the damper. Try moving the thermometer back and forth between the stove top and the flue pipe to correlate how hot the stove is vs how hot the pipe is getting. Let us know what you are reading at various points in the burn.
Lynch said:how many sq ft are you heating with that stove?
and what have you outside temps been?
just wondering, I might be getting one of those stoves too. might be the newer one, but should be some what simaliar.
That's a bit optimistic, methinks. I've never met a basement that does that without huge quantities of btus being stuffed into them. They're great thermal sponges.you’ll start to see an improvement in the room temps you as the basement starts to store some heat.
BeGreen said:I respectfully disagree. Personal experience in this case seems subjective. It's good that it is working well in your case, but this can vary dramatically with different environments.
First, many of the folks here are not in modern houses with isolated slab floors or insulated block construction, or even 3 core block walls. The heat loss via the walls and slabs in conventional construction (say up until the past 20-30 years) is a common case and the losses are significant. You should be able to derive test data on that if you look for it. I know I found some on the HVAC sites for heat loss calcs a while back. Second, many folks here do not have good heat transfer from the basement to the upstairs and do not see this benefit.
I'll be putting up R10 foam board, studs and then drywall. I'll start on the exposed portion of the basement (walk-out) and slowly move to the front. You can definitely feel lots of cold coming THROUGH the blocks. Touching the wall proves it to be sending lots of cold in. I think if I heat the stove up and keep it that way for a couple of days (which is hard when I'm gone all day to work), I believe I would see some noticeable differences. I definitely will be keeping this stove hot all weekend and we'll see how 3 days of heat does.precaud said:First, BK, you, my friend, are the master of mental constructs, not I. Perhaps you have a magical basement.
Battenkiller said:So I take it you're going to disrespectfully disagree with me? :smirk:
