I used a 602 since 1980. It had enamel pipe the same size as the stove outlet (4" ?) with a pipe damper in it. For the first 10 years or so I used paper underneath small kindling with larger spit or whole logs on top. Usually used 2 whole sheets of newspaper crumpled up on top of everything to warm the chimney, and get a good draft going. I would generally keep the air open fully until things were really going well and then close the air down to about 1/2 an inch open and after a few minutes close the damper if I was going for a long burn during hours I would be home awake. For night burns I would close the air to a bare sliver and close the damper. I almost always used either pine, cottonwood, or aspen. Never would it hold a fire more than 8 hours, unless I had hardwood, (1 load of cherry once) then it would have good coals after 8-9 hours.
I ended up using fatwood the last 20 years or so to start it. Usually 3-4 sticks would get things going and get the chimney good and warm for good draft. No more newspaper with the fatwood.
I replaced the top burn plate once and I also replaced the side burn plates. The back does not have any protection and sure enough it finally cracked. I plastered stove cement over the cracks and never had a problem, but I don't think that is really recommended. I believe backs are available, but taking it all apart after 30 years was more than I wanted to mess with.
In your neck of the woods the choice of wood has to be super. With VA temps and good hard wood a 602 would be great. I would only use pallets for starting the fire, and would try to find any type of split hardwoods. Even at high prices I doubt you could cram a cord through this stove this season.
I live in Wyoming and used the Jotul with outside temps of -20 at night for much of the season with usually a drop down to -40 or -50 for a few nights many years.
I might have kept using it had gas not gotten so cheap and the crappy wood in wyoming gotten so expensive, not to mention a wife that is always cold
. It is going to do service next in a wood heated mountain cabin. Maybe I will rebuild it.
When I first bought the stove it had a plate on the ash tray saying "caution stove is hot during operation" My dogs never did learn how to read but they never did touch the stove. I have to wonder about someone being able to read and not knowing a stove is hot. Lawyers, and the government.
