I have a Jotul #8 that is around 7 years old. The stove seemed to end last year without any problems, but during my annual cleaning and dusting of the catalytic I found a 3 inch crack extending downward vertically from the center of the catalytic opening on the rear of the stove. It looked initially like a heavy scratch but on closer examination I saw that it went all the way through the casting. The casting at this point has a shelf teed into it and this is also cracked. The green enamel has also bubbled around the opening. It is not unusual for the temperature (taken 1/2 inch above the catalytic) to get to 1500 degrees but I am always careful to watch it closely if I think there is a chance (unusual) of it running away and I open the bypass to let it cool off. Should I be worried about the crack? What are my options for repair if you think I need to take action. Can I remove the catalytic and run the stove without it? With the catalytic removed the crack would no longer be exposed to very high temperatures as it is shielded from the main firebox. I don't burn very much these days and would prefer to keep this stove if at all possible.
Thanks.
Neil Jefferson
Thanks.
Neil Jefferson
