Thanks to everyone who posted some info concerning my last post, "replacing a franklin stove". After some thought I decided to go out and buy a Jotul Castine wood stove. I have to say that so far I am really happy with it. I have had two break in fires so far. The first fire I had trouble starting, the second went much better. Starting a fire in the new stove is different than the franklin stove. Since I do not have any experience with the new stoves I ask for some help again. Here are more questions.
1. When I first start the stove, I crack the door for a couple of minutes and wait for the wood to catch. Then I shut it completely. Does anyone else have to do that? The Jotul Instructions don't mention this.
2. The flames seem different than my other franklin stove. They burn a brighter yellow blue. On top of the firebox, after the fire burns for a little bit, it looks like there are additional flames burning. Is this what is meant by secondary burn?
3. How many fires does it take for the paint to cure?
Thanks again for your help.
Mike
Mike
. I also like the smooth and easy air control that stays cool even with a hot fire. Fit and finish on the stove is excellent. The rear heat shield really works well. So far I am of mixed opinion on the large door. With the lazy starts, it's hard not to let smoke into the house when feeding the stove and it is not up to temp (at least over 300). I open the door slowly to let the gases equalize, but still get a puff of smoke or two. We'll definitely want to be able to control this. Maybe when the temps drop this will work better? If not, I may switch to top exit and/or try the european air adapter.
