I dont see that to be true just dont hit the dirt and you can cut 3 tanks or more without sharpening! You will never look back!EatenByLimestone said:MS290 with a 16" bar. I need to drop a blue spruce at the family cabin next weekend. I'm hoping for a good amount of fun. I'll be thrilled to get rid of that needle producing bastard.
I'm interested to see how long the edge lasts. I've read that they dull faster then a safety chain.
Matt
It's got nothing to do with the safety rakers, it's the shape of the cutter. Semi-chisel doesn't dull as quick as full chisel and is a bit more forgiving of sharpening errors but doesn't cut quite as quickly as full chisel.EatenByLimestone said:I've read that they dull faster then a safety chain.
Matt
Matt
I think that You'll love the difference in the way they cut . Also, if Your cutting wood that has a lot of dirt, try semi chisel . It doesn't cut quite as fast as Full chisel ,but it wears a bit better in dirty wood .EatenByLimestone said:I'll report back Sunday night!
EatenByLimestone said:instead of the 40:1 that I should have been running.
It depends on the oil, not the saw. Most castor-based oil manufacturers recommend 25-40:1, most synthetics 40-50:1, some synthetics 100:1wendell said:I don't have a Stihl, but aren't you supposed to be running 50:1?EatenByLimestone said:instead of the 40:1 that I should have been running.
I don't know. It's too general of a spec. I imagine it's some form of disclaimer written by lawyers.wendell said:...why would there be a requirement in the owner's manual for 50:1?
wendell said:Well, it must have something to do with the saw or why would there be a requirement in the owner's manual for 50:1?
