Just sold my Hearthstone, what stove should I get?
bruh44
27
North Carolina
I sold my hearthstone because it didn’t do what it was supposed to do. It was supposed to stay hot for hours after the fire burned out, it did not. Plus I could only get about six hours of a burn out of it so I always woke up to a cold house.
What’s next?
My house is 2500sq feet but it’s not well insulated (working on it). It does get into the teens here in western North Carolina. I’d like to get a stove that’s good for 3000sq feet. Something relatively efficient. What do you all recommend? I was looking at the Blaze King King 40, but that thing is over 4K.
bholler
Chimney sweep
Staff member
Jan 14, 2014
31,973
central pa
What’s next?
It also needs an 8" chimney.
EatenByLimestone
Moderator
Staff member
2500-3000 sq ft of not well insulated space is a lot to ask of any stove. How much heat do you need?
begreen
Mooderator
Staff member
Nov 18, 2005
99,726
South Puget Sound, WA
Which Hearthstone stove model was this?
bruh44
27
North Carolina
It was the Heritage. It was very nice looking, just not as good as advertised.
The house is much better insulated now than last year. I had the walls filled with foam but the floor, sealing and timber doors still leak. The floor should be fixed by next winter.
begreen
Mooderator
Staff member
Nov 18, 2005
99,726
The Heritage is a bit small for this size house, even in NC. Going to a 3 cu ft stove will make a noted improvement in burn time, even with a conventional tube stove. In the Hearthstone line that would have been the Mansfield. A Woodstock Progress Hybrid would be a good fit if you want to stay with soapstone.
Reactions: EbS-P
EbS-P
4,488
SE North Carolina
How important are looks and what styles do you like the best. BK Ashford looks nice IMO and has a proven design. Pacific Energy T6 another solid choice. There are more value oriented brands that make decent heaters.
stoveliker
7,261
Long Island NY
I don't think the Ashford will produce enough heat if the home is still leaking.
Do you want a stove for now, or one that can do well when the home is tight?
bruh44
27
North Carolina
I like black stoves with the standard four legs and a large glass front to see the fire. It does have to have a rear chimney hook up.
I’m definitely looking for a stove to stay for good. I’m not really just price shopping. I will spend 4K if it’s the right stove.
Space wise, an insert would be ideal. But my understanding is that they just don’t heat quite as well.
bholler
Chimney sweep
Staff member
Jan 14, 2014
31,973
central pa
Rear vent will be a limiting factor. What size type and height chimney do you have
stoveliker
7,261
Long Island NY
That (rear exhaust) confirms Blaze King is out.
bholler
Chimney sweep
Staff member
Jan 14, 2014
31,973
central pa
It’s a 8” lined with a 6” lined inside of it, so I can use either one. It’s about 25 feet tall.
So you have an 8" liner in a masonry chimney with a 6" liner in it?
bruh44
27
North Carolina
That is correct. The company that added the liner put in an 8” when they were supposed put in a 6”. So they just ran a 6” inside. I can pull it out if I need the 8”.
Yes it is masonry.
Reactions: bholler
bholler
Chimney sweep
Staff member
Jan 14, 2014
31,973
central pa
Yes it is masonry.
Ok just making sure this wasn't a prefab fireplace
begreen
Mooderator
Staff member
Nov 18, 2005
99,726
The Woodstock Ideal Steel can be rear vented. Also, a Buck 91, Osburn 3500, or PE Summit insert will work.
weatherguy
5,917
Central Mass
I'm heating 2800 sf in a northern climate with a Progress Hybrid and it does a good job, also rear vent, the Ideal Steel is also a good stove that's a rear vent.MY PH does hang onto the heat after the fire is out and it's just down to a few coals, works great this time of year when I light a night fire and it's still cool out in the morning and the stove is still throwing out heat. If you go with an 8 inch I'm sure there's other options, not sure if Kuma still makes that big stove they used too.
Reactions: BKVP
BKVP
You know, this came up once or twice before. I don't think the combination of the two liners has a listing. Not that it will get inspected, but I know of no such approval listing for a liner inside a liner.
bholler
Chimney sweep
Staff member
Jan 14, 2014
31,973
central pa
My thinking on it (not that it's nessecarily correct) is that once the 6" liner is installed that 8" one becomes just like the clay liner that is outside it. Not part of the equation. Not the insulation of the liner is a different story when it comes to compliance. If the 8" liner is insulated does that insulation apply to the 6"? In reality absolutely but from a compliance standpoint I don't know.
Reactions: clancey
bruh44
27
North Carolina
I’m looking pretty hard at the Buck Stove model 91 as an insert. In doing that I would be removing the 6” anyways. Yes the 8” is also insulated.
