Kindling Cherry yes or no
cptoneleg
1,546
Virginia
I like lots of good Kindling for starting stove up with very few coals etc. etc. This year am using Tulip Poplar which makes very good Kindling, and had planned on cutting some for next year, but have acess to so much dead Cherry this year,
I was wondering what kind of Kindling Cherry would make cut up into real small splits. I can't see cutting down a live Poplar with so much dead non punky Cherry on hand
  • [Hearth.com] Kindling Cherry yes or no
Would make great kindling
Will dry fast split up that small.
I use birch, it works fine.
^^ yep . Cherry makes very good kindling as does silver maple .
I have used some Cherry for kindling. It is rare for me to get though. It works great for kindling. As does White Ash. That is what I have access to.
I don't care what type of wood it is, if it splits easily I'll use it as kindling. If it's a PIA to split small (I can slide my wedding band over about 1/2 my kindling) then it goes in the stove whole.
I save for kindling whatever will get to that size the easiest.
pen
pen
+1
pen
+1
Exception might be locust, its takes a while to get going.
Posted this photo a while back - I've been making red maple kindling for the last couple weeks. A little more to go for next year's supply. The red maple gets so dry, with a 1/4 Supercedar, it lights off like a rocket! I'm sure the cherry will be great. I've used red oak kindling and takes a little bit longer to catch, but still fast and leaves a nice bed of coals. Cheers!
Is that your kindling splits??? I make mine that size and smaller, mostly smaller
Yes - if red maple - gets so dry that ~ 2" splits light right off with a 1/4 supercedar. There are quite a few ~1" size pieces as well though. Cheers!
I've always been partial to softwood for my kindling -- white cedar or I'll chop up some slabs.
That said . . . almost any wood will do if it is small and seasoned enough.
Cherry is excellent kindling,starts fast,burns hot & smells wonderful.I normally use a mixture of twigs/branches from the yard,corn cobs & all kinds of hardwood/softwood scraps from my shop because I accumulate so much of it every year.
Cherry is cheery no matter how it burns; kindling or splits are fine.
weatherguy said:
pen
+1
This and Osage, there hard starters.
Cherry would be better than Poplar IMO because it will hold a little longer, but burn as well. Poplar goes quick and may not be enough of a base for larger splits to take hold.
Cherry has been excellent kindling for me this year. Burns hot and longer than pine/poplar/birch.
