I got the king hooked up about a month ago. I'm getting 12-18hr burns with birch and some red maple. With as bad as this house is built it does have a hard time heating it from the basement. But if I don't heat from the basement my floors are ice cold. There was no easy way to get the stove down the stairs. My stairway is very steep and narrow. I had to cut the ash lip off to get it down. Plus with a 90 deg turn at the top there was no way to put it on a cart and take it down. The safest way I could figure out how to do it was build a lifting frame into the stairway and lower it with a come-along. While I am going to have to mud and sand some screw holes in the drywall it made it down safe and sound.
(broken image removed)
One thing I have learned so far is that dry wood is absolutely critical. My one year dried wood really isn't dry enough it really needs two that are in a good drying spot. And two that it works better with full loads of wood turned down rather than trying to burn a few splits. With a full load it seems to mostly burn across the front of the wood and what coals fall down have time to fully burn up while keeping the stove temps up. With a few splits it burns the whole split and quickly turns it to coals then I have to add more wood to keep the temp up. But while that is happening the coal bed keeps building up and can't seem to burn up.
Billy
Billy
