KozyHeat Z42 Temperature
aboutte
4
United States
Hello all.
I am new to wood burning and just got a Kozy Heat Z42 installed. I have two questions
  1. Where can I place a magnetic thermometer to get an accurate temperature?
  2. For this fireplace what temperature would be considered overfiring?
begreen
Mooderator
Staff member
Nov 18, 2005
102,380
South Puget Sound, WA
Welcome. It can be a challenge to get an accurate temp with a ZC fireplace. Is this the single or double door version?
Your best bet is probably going to be with an IR thermometer gun right above the doors or maybe on the door frame top itself. On the double door it doesn't look like there is room for a 2" dial thermometer there, but if there is then that would be the best location. On the single door there looks to be room on the upper door frame. Overheating would be above 750º.
aboutte
4
United States
Thanks for the reply begreen.
I have the double door and have attached some images with measurements.
The magnet on the back of the thermometer is just about 3/4" and fits on the top corner of the door.
Is 750º a general temperature for all stoves or specific to the Z42?
EatenByLimestone
Moderator
Staff member
750 is general for all steel and cast iron stoves. The world doesn't end if it goes over it, but you don't want to make a habit of it.
Reactions: aboutte
c604
32
Morgantown, Indiana
I have the cast doors model also and I use an IR gun. This is the second year with it and I really don't use the IR much now. It was a great learning tool. My stove cruises around 425 measured above the doors. I've never seen more than 575 and that was putting out major heat from the fan above the doors. Also my chimney is 26' and drafts great. After burning about 2 cords I had about 2 coffee cups of light grey soot from my chimney last season.
aboutte
4
United States
Thanks for the info. My magnetic hovers at 550. I'll think about getting an IR gun to compare.
