LOCOMOTIVE STOVE and Tender !
coaly
Fisher Moderator
Staff member
5,093
NE PA
$5000
"The locomotive stove weighs approx. 750 lbs. To get some idea of its size, the cross-ties under the rails are 2x4's. The smokestack holds water to act as a humidifier. And there is a separate water tank in front of the cab to provide steam for the attached steam whistle. Also a blower (included) attaches to the rear of the stove to force heated air through the cab "window" exits. The front "nose cone" is hinged so that it opens outward to load wood into the stove. And the firebox is brick lined.
The Tender is the wood box".
(broken link removed to http://www.ebay.com/itm/Locomotive-Wood-Stove-Tender-/110822305923?pt=LH_DefaultDomain_0&hash=item19cd863083)
  • [Hearth.com] LOCOMOTIVE STOVE  and Tender !
Masterfully crafted. Thanks.
Some day I will have enough time to sit arround and not do something this involved, rather than just talking about not doing it.
Very odd. I assume the flu attaches to the smokestack?
It would be nice to know what kind of air control, door seal, log length, steel thickness......... Wonder if that's a safety pressure relief valve for the steam pressure vessel? Anything over 10 PSI has to be A.S.M.E. Certified.
You would think since it blows out the cab windows, the most heat would be extracted from around the exhaust area, probably where the fire door would normally be. Perhaps it would look goofy with a pipe coming out of the cab, and it was never fired?? They could have made a reverse burn out of it with long baffle plates like an Upland and exausted out the stack, forcing it to exhaust against the draft coming in the front.
The "nose cone" is a smoke box door. Obviously they are clueless.
That's what I was wondering. I just asked.
Edit:
This was the reply "The flue outlet is at the upper rear of the "locomotive". So the tender could not be positioned directly behind the stove, but rather off to one side or wherever. Also the stove heats very well and efficiently."
