I want to adjust my log splitter so it only handles up to 18" logs as that is the biggest I can use and to decrease the cycle time. Should I just make a steel block for the fixed end?
			One thing to remember if you use one of those gadgets, Evilgriff.......if you are going to be storing your splitter for a long period of time (especially if it's not in a conditioned airspace), make sure you take that device OFF during storage time and retract the ram the whole way into the cylinder. That way, the exposed ram does not get rusty and pitted, which will eventually lead to an 'effed up' seal and a leaky cylinder....
Yes, it has an auto-detent.Does the splitter have an auto-detent valve on it currently?
http://www.northerntool.com/shop/tools/product_472_472
Good call. I always return the cylinder when I am done using it. I guess the best thing would be to take these off when I am done.One thing to remember if you use one of those gadgets, Evilgriff.......if you are going to be storing your splitter for a long period of time (especially if it's not in a conditioned airspace), make sure you take that device OFF during storage time and retract the ram the whole way into the cylinder. That way, the exposed ram does not get rusty and pitted, which will eventually lead to an 'effed up' seal and a leaky cylinder....
OK so I was in town tonight and stopped at TSC and picked up a pack of those stroke control segments. But they are too small, dont fit on the ram
Thanks, I like that mod better than the spacers!
I think the stop should be placed as close as possible to the centreline of the ram. Down on the beam might cause the base shoe to tip up, putting pressure against the seal on the cylinder. If I had my druthers, I would put my stop pin above the ram by notching out the ejector and welding collars to put the pin through. I got lucky in so far as the play in the shoe is such that it does not lift the ram.Why not drill a 1/2" hole in the beam where you want the retract to stop and drop a half inch nut and bolt in??
