Looking for help on my first install - does this quote seem normal?
Jun 17, 2025
1
Wisconsin
Hi all,
It’s been a lifelong dream of mine to own a woodstove, and my wife and I recently bought a house together — so I’m finally getting close! I’ve been researching options and really have my eye on the Blaze King Ashford 30.2. I love its reputation for long burn times, great efficiency, and classic looks.
Our home is about 1900 square feet in western Wisconsin, and my goal is to use the stove to supply most of our heat through the winter.
I visited the nearest Blaze King dealer and got a quote, but the total came out much higher than I expected — even knowing going in that this would be a big investment. Here’s the breakdown they gave me:
• Ashford 30.2 (Metallic Black): $4,875
• Wood Fan Kit: $443
• Outside Air Kit: $150
• Chase Cover: $850
• Install Labor: $1,800
• Permits: $250
• ICC06 Ultra Black Wood Venting: $1,332
• ICC06 Ultra Black Wood Venting (again?): $1,520
• Termination Kit: $340
• Shipping & Handling: $210
• Total (after tax): $12,245
Note: This doesn’t include a hearth pad or wall cladding, which I’ll need to figure out separately — either DIY or through another contractor.
A bit more context:
• The stove is going in our living room into a stove bump out and venting straight up through the roof (single-story home).
• There’s already a stove bump-out area from a previous install.
• There will be no bends in the stovepipe —it can be a straight vertical run.
Given all that, this seems like a pretty straightforward install to me. But I’d really appreciate insight from anyone with experience:
• Does this quote seem reasonable for this type of install?
• Any idea why there might be two separate charges for the venting?
• Am I better off getting a second opinion or working with an independent installer?
Thanks in advance for any feedback — this is a big project for me and I want to do it right without overspending.
Here's a picture of the bump-out where I'm hoping to put the stove (Right where the TV is)
[Hearth.com] Looking for help on my first install - does this quote seem normal?
The double entry may be a copy/paste error. A guess is that the price might be for the chimney pipe, flashing, and cap. Ask.
The most important thing is to make sure the install is safe, with all alcove clearances honored for both the stove and the flue.
Wow that looks expensive but I don’t think it’s out of line with other bids I’ve seen lately. I would definitely shop around for another bid. Maybe find a local sweep that does installs, could save you a few bucks.
Hi all,
• Chase Cover: $850
• Permits: $250
A bit more context:
If you have other contractors that can quote I'd get them in. I usually try for 3 quotes on major projects.
I know sometimes it's hard to get them in, but I find each contactor has a slightly different idea on how
to do it. You can learn and question them after doing your own research. It looks like you are already
asking for the quote breakdown which is good. The prices of the stove and pipe ect will vary, but once
you know what you need you can google some comparisons. That alcove seems pretty small so check
the clearances for sure.
I was able to save some money by doing part of the chimney install myself. Namely measuring out exactly where the pipe needs to go through the ceiling and installing bracing and the box itself (not sure what that's called exactly) beforehand. So they only needed to cut the roof opening and run the chimney through.
Reactions: Whitenuckler
Just a follow up to Tron above, and not a criticism, but be careful in trying to do part of the work yourself. Assuming you are capable, and have the tools, it may not always be the best idea. Contractor who does the install will have to warrant their installation, and they clearly wont want to do that on parts that were DIY installed. Could cause issues down the road.
This is common in many house repairs, owner trying to save money on plumbing or siding or other major repairs. HVAC contractors almost will never complete an owner DIY mini-split install (purging, vacuuming, leak check, operation check for instance). Just a thought, not a knock on the idea above.
Well, in my case the main work was measuring out exactly where it needed to be, cutting out a square of drywall, adding 2x4 braces for the ceiling box and screwing that to the braces. I obviously had the chimney installer look it over and do the insulation.
I admit that on DIY projects I usually go for 200%, so it's definitively a lot stronger than it needs to be. The ceiling will cave in before that box moves.
But yes, I understand your concern if someone isn't totally clear about what a work implies and if he can complete it safely.
And as a counterpoint, when "pros" install, that doesn't mean they are actually any better than a skilled DIYer that thoroughly reads and prepares well. Sometimes they are worse.
Don't I know it. Back overseas we built a 2nd carport for our home. I had a construction company do the statics and the framework, but all the rest we did ourselves, including the strip foundations and frame anchors. With very, very meticulous planning and measuring, mostly Pythagoras and a tube level.
When they arrived to put up the framework, the max deviation was less than half an inch in any direction. They told me they'd never seen that kind of precision with a commercial foundation. Made me a bit proud.
I have no problem with people doing their own work. But I will no longer let people do part of the work or use customer supplied materials other than the stove. I have just had too many problems and I always get blamed when problems arise.
Reactions: Tron
I went through a basement bathroom addition a few years ago. Normally I would have done the whole thing myself, but because the concrete floor needed to be broken and drains installed (plus other picky tricky drains and vents) we hired a contactor that had the plumber. I had to fire them both before they were done and finish it myself. Some work they did was good,. but other parts they didn't give a chit, and over priced the work. I started out wanting a firm price job. That only lasted 2 weeks, and then I found out they were charging by the hour. When I find a good contractor (like my mechanic) I really appreciate it!
  • Wow
Reactions: Tron
We used Pratt's Chimney for our install this year, although it was significantly simpler as it was going into an existing masonry fireplace. Even so, this quote seems high compared to what we paid. Pratt's is based in Salem, WI -- not sure how close that is to you (or if you've already moved ahead on this project). Great service.
If you know which end to pick up a screwdriver, and you physically able, the chimney install is pretty easy
Being able to measure properly, ask questions, plan in advance, and closely follow instructions helps.
That is less than I paid to have my stove installed earlier this year. Your quote more competitively priced too, but I live in an expensive area. One suggestion if I may, is to order the Ashford in the enamel finish. It looks great and is infinitely easier to keep an enamel stove clean than a matte finish.
Hey. I'm in western Canada. Similar situation as you. Straight forward install, single story home, similar square footage. I was surprised to see how expensive your quote was, especially because everything in Canada seems to be quite a bit more expensive in comparison. Anyway, below is the quote I received about a week ago from my local BK dealer. My quote is for the Princess 30. I appreciated our dealer listing out all of the piping in the quote (They came out and did some initial measurements). Maybe you could ask your dealer for a better break down?
EDIT: The "Custom Sheet Metal Work" is a heat painted flat piece of sheet metal they are putting down on the floor as a hearth.
For quite some time the exchange rate has made all of the canadian quotes seem super high. Now, with the tariffs and other issues, your price is looking dang good up there.
Happy canadian Thanksgiving Pete!
Reactions: Pete16
Canadian pricing is higher. More like wow how prices have gone up over the years.
Reactions: Todd
