Looking for some guidance on fireplace
hardboiledeggs
11
saskatchewan canada
Hello. Calling for help from Saskatchewan Canada. I have a house from the 50s with an absolute unit of a masonry fireplace. The whole unit is 17 wide by 17 tall by 4 thick of field stone.
Chimney is the wall of the corner of the house and has one inside fireplace and one outside. Currently the inside fireplace is a regular open fireplace with glass doors. Unit also has some convection Vents that seem to run behind the fire backing and to the other side Vents. Also has what I believe is an outside air vent that goes outside and comes up under the firebox.
Damper in the chimney is gone so cold air and wind blast down in the winter so I'm looking at upgrading to a modern unit. Current firebox is 48 at the front 44 at the back 29high and 24 deep.
Was looking into inserts but can't find anything that I really like. Want to maximize width and have double doors. I know I likely will have to cut some of the stone to expand the opening vertically but I have a masonry saw and am not intimidated by that. Been doing some digging and saw a few units that intrigue me.
Osburn horizon
Superior fireplace wct2042
Rsf focus sbr (single door but width works)
Can anyone tell me if I'm on the right track or totally out to lunch?
Don't need it as a primary heat source but would be use regularly in the winter.
Let me know, thank you!
[Hearth.com] Looking for some guidance on fireplace[Hearth.com] Looking for some guidance on fireplace[Hearth.com] Looking for some guidance on fireplace[Hearth.com] Looking for some guidance on fireplace[Hearth.com] Looking for some guidance on fireplace[Hearth.com] Looking for some guidance on fireplace[Hearth.com] Looking for some guidance on fireplace[Hearth.com] Looking for some guidance on fireplace[Hearth.com] Looking for some guidance on fireplace[Hearth.com] Looking for some guidance on fireplace[Hearth.com] Looking for some guidance on fireplace
  • Love
Reactions: ispinwool
It's beautiful but, that's a HUGE heat dump into the great outdoors. Especially with your climate, I'd want that gone.
If it was my house i'd try to get a free standing woodstove in there. But that's what i like.
Reactions: all night moe
You want to be shopping for wood burning inserts not zero clearance fireplaces or a free standing stove. You will be required to run a full SS liner. Insulate behind and around the insert add a block off plate and insulate above it.
I don’t know of any double door inserts. That’s a big opening. It at 29” high your stove choices will be limited. Check Osborn Pacific energy, for inserts. Maybe a jotul F55 with short legs.
I would install a large wood insert in there with an insulated, 6" stainless liner. There should be an insulated block-off plate and I would insulate behind the insert if possible. The insert will have a single door, but that is actually a good thing. They usually seal better.
Reactions: profdlp
Curious why insulate behind insert? Would that actually retain a lot more efficiency?
It's to keep more of the heat generated in the room. Otherwise a significant portion is radiated outside. A FLIR camera illustrates this pretty dramatically.
To be clear you are saying insulate the 3 walls of chimney where insert will be as well as block off plate. I guess it’s anecdotal but how much more heat does one gain from that? How much clearance would be suitable?
Anything will help. How much will depend on how much insulation value is in place. Typically 1" Micore or Roxul board are used. The heat gain is significant and notable.
PS: no insulation on top of the insert, however.
pretty well have myself sold on a osburn horizon now. going to pull the old firebacking out and cut the stone above to fit the thing in there. have a couple questions for set up though.
the two vents on the side of the fireplace are connected by a square tube behind the firebacking and im going to have to cut that out but im wondering if it lines up close enough if i could knock out the gravity vents on the unit and leave it unhooked and just let the heat naturally find its way out of the vents or is that a recipe for disaster?
also wondering on outside air kit. currenly it has outdoor air drawing from beneath the fireplace is that useable in any capcity with this new unit or is it worth it to drill a hole for an oak?
Is that "outside air' from the fireplace floor an ash dump? or an outside air pipe?
An ash dump does have a cover to keep the floor closed. Then when removing ash you pull the cover off and sweep ash down the hole. There should be another door below that to open so you can shovel the accumulated ash out. That door can either be inside or outside of the house. If inside it's usually in the basement.
i can't tell from your pics but that 1 pic looks like an ash dump to me.
one more thing, called osburn to pick their brains a bit and they say it is not possible in any way shape or form to install a zc fireplace in masonry. my flue is 12x12 id straight up and down so i see no issue in getting the chimney pipe in. also its stone through and through so i dont see any fire risk. has anyone attempted what im thinking of doing? other than hooking the thing up which wont be a fun endeavor, why cant i put it in there if i can get the chimney pipe down and fit the thing in? thank you
it goes to the outside and i cant see anywhere where ash would be logically taken out of there. either or think i can use it as an intake?
Ok then i guess it is some type of outdoor air feed or a spot to run a kit?
I forget why a z clearance fireplace instead of an insert?
Reactions: stoveliker
I'll vote 1 more time for a freestanding woodstove. If the answer is still no why don't you just leave what you have now and stuff a piece of insulation up the chimney when you are not using it, if you are not using it much?
or get a damper that installs on the cap that has a chain down the flue to inside the fireplace to open and close it.
Hi hardboiledeggs,
I'm new to the forum and am curious how your project is going and what was the outcome. Would you be willing to share a photo?
I have a similar fireplace in a cabin we purchased 4 years ago. We inherited a converted wood-to-LP gas setup installed with a Blaze King 8003 insert. We are having an immediate issue with the unit not shutting off (running continously), even when thermostat is turned off. So this needs to be fixed ASAP. But more broadly, the installation was rather janky and there are gaps on the sides that they stuffed with insulation. Looks TERRIBLE. I'm wondering if there are now better solutions that could replace this unit?
  • [Hearth.com] Looking for some guidance on fireplace
Hi hardboiledeggs,
The same issue will be present with a new insert if it is switched back to wood. The issue is the rough stone opening. One option is to have custom, scribed panels cut and then attached as wings to fill the gaps where the insulation is now used. The much smaller gaps then could be caulked with black silicone.
Reactions: swinkelb
begreen - thank you for your reply.
Not sure if this is the right thread to ask, but I'm also wondering - does anyone have a suggestion for how to clean the black soot off the front-facing hearth over the insert?
It’s called “paint and peel” I believe.
Reactions: bholler
I should get some of that too. Have had black soot stains for 20 plus years behind the woodstove.
