Ok, I realize that this may not be the right forum for this question, but I imagine that I'm not the only person looking to maximize efficiency from their oil burning furnace now that they are heating their home with wood.
For the last month, I've pretty much primarily heated my house with my jotul 550 insert. It's doing a great job. But I still hear my furnace kicking on every now and again and I hate that. I have all the thermostats turned down or off, but I still need the furnace for domestic hot water. I have a buderus system with a logamatic 2107 control.
My question is this...what should I keep the high temp limit on the control at? I currently have it set at 140 deg and have my hot water set at 120. Would it be better to set the high temp limit higher so it won't have to turn on as often? Or lower, like the same temp as my water...120? I just don't know what I should do to try to limit the burner from turning off and on as much.
Maybe I'm over thinking this. I just figured someone here has been through something similar.
Thanks in advance.
John
Thanks in advance.
John
