Monaco zero clearance
woodhot
I’ve got zero clearance Monaco wood stove. Not pleased with burn time and suggestions I’ve checked the draft everything is hooked up as it should be. Burning dry birch for wood, Any other suggestions? Maybe 4 hours tops when filled up. Puts out great heat, but would love to be able to keep a fire in over night.
Dry? Have you measured the Moisture Content?
White Birch? Yellow Birch?
What size are your splits?
How much are you cutting the primary air back
once the fire is blazing?
Yea, what diameter? Some people split things down too thin and it burns like kindling because of the surface area.
