Mp240
Jiga
9
Massachusetts
Hello all,
I have an older earth stove mp240 pellet stove. I noticed it is leaking oil or grease from the the back of the stove. Looks like the auger motor. Is this something that can possibly be fixed without replacing the motor! Can't seem to find a ton of information on this stove online.
Thanks in advance.
Jeff
No,well,if it is coming from the auger motor,you could take apart,clean old grease out,pack with new hi temp grease,not worth it.Are you sure it is not creosote leaking from the stove?Picture.
Could be Bob. Not sure just noticed a straight line of oil or grease on the backside of my hearth. got under there with my headlamp and looks like the auger motor is leaking? Thanks for your response
The grease in the gearbox may have broken down and is leaking out of the gearbox. You could run it until it dies, but opening up the gearbox, cleaning it out, and installing new high temp grease would make it last much longer.
Thanks i will look into what's involved. Guessing there's a gasket involved. Not sure if I'll be able to find a replacement but can always make one
Thanks again....
just in case :)
(broken link removed to https://www.ebay.com/itm/281295959964)
